Quick question when i go into first and let off the clutch and gas my car makes a clicking noise same thing when i put it in reverse does anyone know why this is happeneing the car is stock its a 07 versa s 6 speed with 3500 miles????.......
Postby
PB »
https://forums.nicoclub.com/pb-u69414.htmlFri Jul 27, 2007 7:24 am
I know some one else with a manual that did the same thing,He did not know what it was,I have a auto so i am in the dark,Call it the clicker if you have a 6 speed.
Postby
ThirstyRoss »
https://forums.nicoclub.com/thirstyross-u64862.htmlFri Jul 27, 2007 8:01 am
I have a 6spd, and I don't hear any "clicking". I do hear a bit of a "clunk" when I first put it from neutral into first, and have assumed that was a normal sound when the transmission gets engaged.
Postby
Ever Victorious »
https://forums.nicoclub.com/ever-victorious-u44595.htmlFri Jul 27, 2007 8:43 am
The "clunk" when shifting gears is normal. a "Clicking" noise when you start to release the clutch into R or 1st is not normal. I'd be worried that you have a syncro out of whack or aren't completely in gear.
its a clicking sound for sure not a clank....i asked some car buddy and they say it might be the cv boot? anyone agree??......i mean its not like once in a while it does it quite often not good for a brand new car agree?
Put the front up on blocks. Grab a drive shaft & turn it back & forth. Does it make the same noise you hear in the car? If so it is just the slack in the differential from changing dirrections.
Postby
lain »
https://forums.nicoclub.com/lain-u38819.htmlMon Sep 10, 2007 5:57 am
XterraVersa wrote:Put the front up on blocks. Grab a drive shaft & turn it back & forth. Does it make the same noise you hear in the car? If so it is just the slack in the differential from changing dirrections.
