CPJ LB »
https://forums.nicoclub.com/cpj-lb-u166947.html
Sun Aug 07, 2011 1:31 pm
...bringing this thread back to life...
i recently experienced a 'clink-clink' type of sound when i would engage from Park to Drive, Drive to Reverse, Park to Reverse, etc...the noise sounded like someone was hitting a piece of tin with a metal tool or something. I was getting concerned if something was going to fall off or break...
I took the car to my mechanic and he was able to duplicate the sound when he shifted from Park to Drive, etc...he looked under the car and found that the rear axle bolts/nuts were loose so he went and tightened and re-tourque everything from the front/rear axles, driveshaft, differential, etc and he tightened things up regarding my suspension...
the noise is gone...thank goodness...
I'm not sure if more of you are/were having this issue, but it pays to have it checked out to avoid any future issues...hope this helps...
