Can you be a little more descriptive? Speed? Severity? What was their fix the last time?johnatwi wrote:Hey everyone, I am new here. I have a 2007 Nissan Versa SL with CVT transmission. I had this problem before but they "corrected" it but now it is back. I seems whenever I am driving and I make the slightest turn of the steering wheel, even just changing lanes, there is a clicking noise coming somewhere from the steering column area. Has anyone else ever experienced this? Thanks a lot!
I always lube my shaft before using it.alonsorules8 wrote:It sounds like your steering shaft need to be lubricated, doing this takes care of clicking noises from the steering system.
Chevy Impala's had this problem and with lubrication of the shaft noises went away.
Yes, your description is correct. Not very loud but it does catch my attention.morgan wrote:Without hearing it, This sounds, depending on the volume, like the clock spring right behind the steering wheel. I have heard both these noises coming from Versas at this particular part. I would describe the non clicking noise as a scuffing, correct?
