sprocket »
https://forums.nicoclub.com/sprocket-u136001.html
Sun May 11, 2014 6:26 am
The sound is normal and comes from the BCM, there's a relay in there that turns on and off when the rear wiper is operating.
When running in intermittent, the BCM monitors the stop signal to know when the wiper has returned to its stop postion and turns off the relay temporarily, then turns it back on when it's time to wipe again. There are actually two clicks for each cycle, one when it turns on and another when it turns off as the relay contacts engage and disengage each cycle. The first click is usually more audible which is what you're hearing at each wipe.
When running in just ON, the relay only has to click on twice when you first turn it on again when you finally turn it off, since the wiper runs continuously and the BCM doesn't have to "pause" the wiper intermittently by starting/stopping the relay.
