I had this issue on my 01 Acura MDX. Rubbed the window seals with WD-40 and it never returned.... Good luck.smoon4 wrote:Hi,
I had same problem and went to the dealershop, but they told me it was caused by seat belts.
The problem did not go away at all. Noticed that when I opened the window slightly, those noise went away. I applied the pure slicon rube (treadmil rube) around the top rubber section. All noise went away..
The rubber section and window or matal parts on the door were rubbing each other and made anoying noise when the road was uneven.
