Clicking noise coming from behind drivers side door panel....
andrewdees
Car: 97 Emerald Green SE
hey guys I did an SR swap about 1.5 months ago. Since then I have been hearing a clicking noise coming from behind the drivers side door panel. Ive noticed that everytime it clicks the temp gauge will go up a little then it will click again a few seconds later and the gauge will go back down. I do notice a slight change in idle everytime it clicks. It almost sounds liked . The a relay clicking but I wasnt sure if there was any kind of relay in the drivers door.
Before I did the SR when I still had the KA this never happened. Any input would be appreciated. Thanks
andrewdees
bump bump
da40
Car: 1995 SE 240sx
hmmmmmmmmmmmmm
andrewdees
ttt again......im stumped on this one. I took off the door panel and I can clearly hear a click noise coming from behind the metal. Maybe ill just start taking off parts behind the door and see if i can find out what it is.
xero1
Car: 08 Altima Coupe
could be a bad ground. disconnect all the connectors behine the door panel and see if the noise goes away.
