I started getting a clicking noise at low speed. I changed the differential and transfer case oils using the guides (diy-nissan-rogue-transfer-case-fluid-ch ... 54009.html and diy-rear-differential-fluid-change-t554006.html; thank you, 5.56) in this forum but the noise did not go away. Took it to the dealer and they fixed it under the power-train warranty (5 year). The repair report says
"MB13AA R&I/RPL both front drive shaft assy's - *
Clicking coming from front axles from inside hub housing. Removed both front axles, lubricated axle splines and hub housings and re-installed front CV axles"
Found this http://www.nissanmurano.org/forums/atta ... 093-1-.pdf on the Nissan Murano forum
