Clicking from the rear... common on the 350z, how about the s14?
98koukile
Car: 1998 Nissan 240SX LE
I have a clicking from the rear of my car and before I jack it up and play with it I'd like to know if anyone else has this problem. It changes with speed leading me to believe its either the axles, a u-joint, or something in the brakes. If I've been on the highway for a long time and brake hard for something it comes back heavier than usual. I was thinking about purchasing a 1 piece driveshaft and new rear brake calipers anyways since I've had some problems with both things but I may need to hold off in case I need new axles.Anyone have the same noise?
98koukile
Nobody has had this problem? I guess when it stops raining I'll have to check it out
docrez
Car: 1996 240sx
Mines just started clicking too, except mine happens when I take off from a stop. Hopefully I can get it on the lift this Sunday
grecco28
Car: 1992 240sx
one time my s13 have this problem to and i just lubricate the cv joints where it comes together with he hub... and t he click goes away...
newbissan-tech
Car: 96 vh45 swapped 240sx SOLD, 2011 frontier pro4x SOLD, 08' Altima SOLD, 2006 TITAN, 2012 SUBURBAN FOR THE FAM.
yes this is common i work at a dealer just pull your axles out rotate them 180 and put a lubricant on the splines when you reinstall them! if that doesnt fix them then your axle is probably bad! good luck man!
