maxnix wrote:210K an driveshaft never replaced? Probably need a new one.
Sound more like the transmission mount to me..sitting too high causing the rubber flex disc or "Guibos" (as someone on the club informed me) to stretch.
China, you should probably send back the nismo and get an OEM mount. If it's stretching that much the integrity of the guibos may have already been compromised. They are not items you can purchase separately if buying from the dealer..you have to buy the whole shaft. Don't pull the nuts on the guibos as they are not meant to be touched (per FSM).
I have a few (guibos) sitting in my garage but again...it wasn't meant to be pulled so..... Learned that the hard way when my mechanic pulled it during transmission replacement and am now dealing with some vibes. I am currently eyeing a drive shaft sitting on a Q in a junkyard. The shaft was pulled where it was connected to the diff, but the transmission side is still connected...
