mkory »
https://forums.nicoclub.com/mkory-u17964.html
Sat Oct 23, 2004 1:32 pm
Okay, I've found that its the return spring (the coiled one) that is sticking to itself, and when it breaks free it pops. I've WD-40'd and greased the hell out of it and it's still doing the same thing. Does anyone else have an idea to stop the sticking that doesn't involve replacing the spring? I'm fresh out of ideas and I can't tell exactly what replacing the spring would require, but from what it looks like, I'd have to twist the spring so it can set on hook on the pedal arm to pull the arm forward. The clutch pedal is hard enough to push in by hand while I'm down there (akward position too) and I can't even imagine twisting just the spring by hand to get it in place. Ideas?
