Clicking at low speed
atlM35
For those of you, including myself, who thought that the clicking was a universal joint:
I met a guy last week who just opened up his own independent shop. It turned out that he was a master nissan/infiniti tech for over 20 years and no longer wanted to work for a dealership. I mentioned to him that I had a clicking and that I thought that it was the universal joint. He knew exactly what it was and said that it was common for Infiniti rwd vehicles to make the noise from the axle splines. He said that removing the rear axles, re-greasing them, and installing them turned 180 degrees from the original spot, and a hub re-torque on each side would fix the issue.
I dropped off the 45 this morning and after a few hours in the shop (had a few other things done while I was there), I couldn't be happier with the ride.
CPJ LB
Car: 12 G37X Sedan- stealthy modded
14 Altima 2.5
08 Tahoe
06 M35 S (gone)
14 Versa 4dr (gone)
^ nice!!!
great find...are you located in So Cali?? I'm looking for a new mechanic since my guy moved out of state :frown:
good to know he has experience with Infin/Nis :dblthumb:
can you provide the shop/mechanic info :woot:
thanks,
Anthony
seymore4
Car: 2012 M56
Professional UPREV tuner
Very common with the G35/350z's as well, thanks for posting up
atlM35
CPJ LB wrote:^ nice!!!
thanks,
Anthony
Sorry, I'm located on the other side of the country in Atlanta.
I would rather be in SoCal sometimes.
bicsintegra
Car: '06 Infiniti M35
'06 Infiniti G35 Sedan (daughter's car)
'11 Ford F-150 FX4
'13 Ford Edge Sport
2020 Infiniti QX 80
what was the name of the shop in Atlanta? are they still open?
bicsintegra
'11 Ford F-150 FX4
'13 Ford Edge Sport
2020 Infiniti QX 80
this worked for my clicking noise, thanks.
midnightclub619
Car: 2007 Infiniti M35x
yes. i also had this clicking noise, couldn't figure it out for a while. i kind of procrastinated on finding the root problem but my propeller shaft was 16 years old so then lifted it and found the u joint was going out. i replaced the entire propeller shaft with no issues. i got lucky and fixed the issue in time.
