clickin
02pathy
2002 pathfinder le 3.5 auto 4wdjust wandering if ne had a similar problem. when turnin left and brakin at the same time i get a clicking noise n vibration by the driver side front wheel not sure if it is the axle or wheel bearin, brake related or what but it only happens when turning left during braking other than that it doesn't happen or is not noticable
thank in advance i am truly happy that i found this web side so it far seems great hello to all
Sounds very much like a wheel bearing.
Although, if it is a "deeper" sound it may very well be a CV joint.
I would replace the bearing first, then test.
Welcome aboard!
xekushnr
Car: '90 Nissan 240SX Hatch
+1 to the wheel bearing. i suppose it could also be a ball joint, but im about 90% sure that would be a wheel bearing.
02pathy
i am thinking it;s the wheel bearing too the axle would b more constant n more of a cluck or clunk noise and would make the noise all the time when turnin regardless of brakes or not. but it only happens when turnin left and when the brake is applied like slowin down and makin a turn creates some kind of pressure on the actual bearing itself. never really had an experience like this before but i have to look into futher
thanks for all the inputs so far
