clerifying a couple things about the 5spd swap (89 240sx)
le_ryan
Car: Mazda3
91 Nissan 240SX SR
All parts are from an 89 to an 89
I have:5spd transmission/shifter5spd driveshaftclutch/presure plate/fly wheelclutch pedal/masterblock to transmission plateslave cylinder
I need:brake pedalhard lines5spd transmission crossmembershift bootshift boot to metal circle bracket (used to hold boot to tunnel)5spd center council trim
I dont need:5spd ECU
Does this look correct to you guys?Thanx
SeVa-S13
Car: '05 GTO 6spd
You CAN run the auto ecu, but it'll run alot better with the manual and they're so cheap so why not? My main problem with the auto on the manual transmission is the revs stay up way too long after letting off the gas and going into neutral...
BobWithBoobs
Car: 89 couple with s14 dohc swap.
sounds good for speed shifting
whiterps13
Car: white LE hatch
SeVa, is that right? I know some people in the KA forum were trying to figure that problem out after the 5 speed swap, and changing the ECU was the only thing I could think of. God, Im a genius.
le_ryan
Car: Mazda3
91 Nissan 240SX SR
so i may or may not need the ECU.what about everything els, does that all look good?
SeVa-S13
Car: '05 GTO 6spd
You do not need 5spd center console trim, the auto part will detach from underneath and should reveal mounting points for the shift boot.
Also if I remember correctly, just turn your auto transmission Xmember around and it should mount the manual.
le_ryan
Car: Mazda3
91 Nissan 240SX SR
so i just need to turn the crossmember around and the bolt hole line right up? are you sure? it just sounds too easy.how is the driveability with an auto ECU, i've heard talk about a bouncing idle if the 5spd ECU is not used.
Driftless240
Car: 1991 Hatchback
I am happy mine came stick, even though its a nice project it just seems like alot of extra work. On top of that my friend went in to get his clutch changed when he bought his car and the 500 dollar job turned into about a 750 dollar job. Reason? They had to shim out the Slave and Master Cylinder to get everything to work 100%. Good luck on the swap.
SeVa-S13
Car: '05 GTO 6spd
Tell your frind to drive up to Buffalo Grove if he wants a $500 clutch job. I'll be happy to rob him, lol.
And I may be retarded, but wtf is "shimming" the master and slave cylinders? The slave is hydraulically connected via a flexible rubber hose at the point where any fitment issues may arise. And they shouldn't even have to touch the master cylinder except to unscrew the top to bleed the system, which is unecessary too.
SeVa-S13
Car: '05 GTO 6spd
vroom-chirp wrote:so i just need to turn the crossmember around and the bolt hole line right up? are you sure? it just sounds too easy.how is the driveability with an auto ECU, i've heard talk about a bouncing idle if the 5spd ECU is not used.
I *think* the Xmember turnaround should work. It may sound to easy; but it also sounds like something a large company trying to maximize profit and minimize parts would do. The only car I ever used an Auto ECU on was a friend's 92 convertible and it idled fine from what I remember. The only gripe we had was the whole enrichment at off throttle, causing the revs to stay up longer and fall slower -- but it wasn't all that bad and I believe his sister still drives the car at college every day.
le_ryan
Car: Mazda3
91 Nissan 240SX SR
OperationSr20 wrote:I am happy mine came stick, even though its a nice project it just seems like alot of extra work. On top of that my friend went in to get his clutch changed when he bought his car and the 500 dollar job turned into about a 750 dollar job. Reason? They had to shim out the Slave and Master Cylinder to get everything to work 100%. Good luck on the swap.
Well i prolly wouldnt be doing it, but the car came with almost everything i need to do it, i couldnt resist. Now if i had to buy ALL the parts i would just buy another 240 as a 5spd.H3ll, buying another 240 is harder than swaping to 5spd
le_ryan
Car: Mazda3
91 Nissan 240SX SR
Thanx Seva-S13
350gtboi
You also need the M/T Flywheel bolts and the bellhousing Bolts of an M/T. The M/t bolts are longer than the A/t.
le_ryan
Car: Mazda3
91 Nissan 240SX SR
^ ^ ^ hey thanx man... that could have been bad
