crzycav86 »
https://forums.nicoclub.com/crzycav86-u9237.html
Mon Feb 21, 2005 1:03 pm
First of all, do you have a really limited budget? If you do, a lot of your options will be limited by that.
For injectors, I suggest you get the 460's because it'll give you some extra fuel when it becomes necessary. The safc will work fine with it. Remember, if you're on a limited budget, you may have to settle for 370's that you can get easily from the classifieds.
You tap the oil feed line from the oil pressure sender. It's located under the oil filter. You can get an oil line kit from various places. The return drain line from the turbo has to go to the oil pan. There are a few older threads that give more detail as to where the best place to tap is located.
The downpipe connects the turbo to the cat.
The blow-off valve vacuum line is tapped from the fpr vacuum line. Again, you can do a search to find where that is. If you can't find it because the search function is screwed up, or don't find what you're looking for, you can start a new thread.
A lot of turbos come with a wastegate. It's called an internal wastegate. There's a little vacuum line that comes off of the wastegate actuator. You connect this line to the intake, or a vacuum line. There's also an external wastegate, which does the same thing, but is integrated on the manifold... but I don't have any experience with them. But I think an internal wastegate with a boost controller can meet your goals.
A good way to see where everything hooks up is by looking at a KA-T engine bay, and naming all the parts. You can look in NICO members' rides for KA-T engine bays, or in the thread that's still on the front page.
Good luck with your project.. and remember, NICO is here for you!
