i have no clue what you're trying to say...sbird1 wrote:Pressure washer, dude. Don't rub. Spray.
as i stated before i tried pressure washing first and it didnt net the greatest results..sbird1 wrote:My Mustang sat under a tree for about the same period as yours. Then it came home and got covered in pollen. I pressure washed it and it came out beautifully. Took all pollen, sap, mold, whatever else right off.
i used a kohler combustion engine pressure washer. it's brand new, practically. It's a "good" one... mind you not a honda or anything...Dattebayo wrote:Yeah, but did you use an actual pressure washer or one of those stupid non-engine powered POS's?
?? i am very afraid to hit my baby with "some power"sbird1 wrote:Yeah but, as you stated, you used the lowest setting. Don't be afraid to hit it with some power. I used the "general use" nozzle and it worked like a charm.
C-Kwik wrote:You might try a clay bar as well. Its a lot less abrasive and pulls stuff out of the paint. This might reduce the amount of clear that might need to be removed to get all the gunk off. Depends on what the material is and how it is bonded to the paint. But if it works, you can still buff the finish to increase the shine.
