Clearance
pimpingurz
http://cgi.ebay.com/ebaymotors...14002
i bought this few months back for $225. runs great.
szh
Car: 2018 Tesla Model 3.
Out of curiosity, did you get the curved or straight slots? Any thoughts as to why the curvature, or lack thereof, makes any kind of difference?
Z
pimpingurz
good question. i bought the curved. not sure of the differences between the 2.
PalmerWMD
Car: 2004 350Z
The curves will have present more trap/cooling area, to the air flow for more cooling (a curve is longer than straight line)In the staright ones, the less loss of surface contact area in the straight one, may make for more immdaite "bite".
At least in theory those are the trade off's either way ,in practice I suspect no difference will be noticable.
Fred...:)
szh
Thanks, Fred!
Z
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Im glad to hear good reviews about them... I wanna get these when it comes time for brakes (probably not for a while).....
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Stillen Brembos from Joe were $175 for the front pair, last time I bought them two months ago.
louiegz
Car: 2003 BMW 330i, 2007 Audi A3 3.2 Quattro
Do these Brembos make any noise when you brake? I hate skeaky brakes! Do the pads wear out quiker than using stock rotors? Do you have to use diferent pads or the stock ones? My next brake job will need rotors and this seems like a good deal.
90Q45blue
Car: 2006 Honda Accord EX-L
maxnix wrote:Stillen Brembos from Joe were $175 for the front pair, last time I bought them two months ago.
These would be the ones I would go with if I had to do it over again. Right now I have new OEM's.
Nick
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
louiegz wrote:Do these Brembos make any noise when you brake? I hate skeaky brakes! Do the pads wear out quiker than using stock rotors? Do you have to use diferent pads or the stock ones? My next brake job will need rotors and this seems like a good deal.
It's a good deal in that the rotors are heavier and will resist warping longer. However, they can''t be turned.
Running them with stock pads on my Austin Q45 and am very pleased. Will convert Seattle Q45 within a year.__________________Brian1995 Q45 & Q45t & 2000 Q45
Discover the power of the button!
szh
In my case, for my 95Q, I used Bradi's (not Brembo's that you are asking about, although they are sort of sister companies from what I understand) that I bought from irotors.com (they also sell on eBay) and OEM Infiniti pads. This was an excellent combination ... no squeal, just a bit of typical slotted/drilled rotor sound (not a bad noise, either) when braking. Consistent braking feel and good performance!
Z
pimpingurz
http://cgi.ebay.com/ebaymotors...13987
these are the front 2 and are $99.
i bought all 4 and are using metal master pads. no squeeling and works pretty well. i like them alot. they use to go for more awhile back. very good deal if you ask me, might be able to find cheaper somewhere else. if do please post.
edit;i have abosolutely no sound when i have my windows down. whether i'm braking hard or soft.
pimpingurz
cheap pads will give u the sqealing sound. i don't know which ones are good, but i'm using the metal master for my J30. i've replaced all four rotors and pads and no sound.
elwesso
2007 BMW M Coupe
I have a bit of semi loud squeaking (when the windows are up i can hear it sometimes) when i press the brakes lightly... it only lasts for a 1/2 second or so....
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
I came very close to buying these, but ended up getting the same rotors a little cheaper, from another eBayer (rotorsrus2000). The guy responded within hours of my inquriys, made me a sweetheart deal on the fronts ($100.00, shipped), and I got the rears for $50.00 plus $34 shipping. The rotors are straight slotted, cross drilled, and zinc plated.
He responded to every inquiry promptly. He shipped the product the day after I paid. I even got a tracking number emailed to me, from UPS.
I an not too crazy about not being able to true them, but ever since I started breaaking in my pads and rotors, I have not had any brake vibrations.
I will give a full report on them, when I install them. I still need to get the Tokiko Blues, and the brake pads, before I do a full installation. I plan to use OEM pads from Joe.
My neighbor has a commercial steam cleaner. I am going to borrow it, put the car on jackstands, and clean the entire suspension, engine, and underside of the car.
louiegz
Originally posted by maxnix"It's a good deal in that the rotors are heavier and will resist warping longer. However, they can''t be turned."
__________________
Excuses me when I fumble with the terms. I’m not a mechanic, so I’ll probably have a lot of stupid questions. When you say that the rotors can’t be turned, you mean that they can’t be resurfaced, right? Then if you can’t resurface those Brembo rotors, do you have to change your rotors every time you need to replace your pads? As all you first gen Q owners know these cars are a bear on their brakes. My 67k Q is on its third set of pads, and it does a lot of city driving. If I’m changing my pads and rotors every 25k or so, that isn’t cost effective for a little better braking performance. If that’s the case with the fact that the rotors can’t be turned, then maybe the stock rotors, which work fine and can be resurfaced about three times, is the way to go with me.
NY94J30
Car: 2000 Q45 AE
Brian,
What would you estimate the life is on the brembo rotors, as compared to the 40k(?) for OEM?
diamondj30
Car: Not to low , not to high , just right .
whoever said you cant true crossed drill is wrong,they have to be reground not turned.but they are styill right cause you cant turn them,but you can true them up.want badass break system,go porterfield.if you cant getm 180.00 dollar pads for there heat treat-cryogenically treated rotors forget nit.remember sometimes you get what you pay for.i think shucks has ten dollar rotors.brembo-works.
PalmerWMD
Car: 2004 350Z
louie:No you wont have to buy new rotors everytime you need new pads.
I've have crossdrilled redone before, the shop called it "turned".Mayb should ahve been "reground".
Fred...:)
diamondj30
its all good fred.im happy to be back/.computor you know-upgrade.still lovin your avatar fred.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Haven't had the Stillen (brembo) rotors long enough to comment on wear. I have been told they can be turned, but only by someone highly skilled with excellent lathes and bits. The main advantage is they weigh about 4 lbs. more than stock, even though drilled. I would get them solid if I could.__________________Brian1995 Q45 & Q45t & 2000 Q45
