bullet@TheBeach »
https://forums.nicoclub.com/bullet-thebeach-u40092.html
Mon Aug 28, 2006 2:04 pm
The problem is that I ended up with a bent rod that had slapped the piston wall and put a good dent in it near the blttom. Then after the rebuild the oil lands on all 4 pistons cracked while it was on the dyno on the first run. So there is some marks on the walls that need to be cleaned up. He thought .20 over might not clean it all up. I could not find another block, so I have to go this route. Ten some guy told me that the clearance needed to be different for a car that is boosted than a car that was not. I was just checking to see if that was true.
