clear the codes
daniel577h
Car: rx7
how do ii do this? In the FSM it says crankit over 55 times, does this mean keep cranking it? or to crank it stop, crank it stop, over and over again, can someone help me out. i not to good with electrical yet.\\
thanks, danny
rico05
Car: 1992 RMS13 w/ CA18DET
unhook the negative battery cable for about 15-20 minutes. that is all you gotta do!
float_6969
check the codes, (mode 3) when you go to mode 4 after checking them, it clears them.
boost_boy
daniel577h wrote:how do ii do this? In the FSM it says crankit over 55 times, does this mean keep cranking it? or to crank it stop, crank it stop, over and over again, can someone help me out. i not to good with electrical yet.\\
thanks, danny
Read the FSM or take the advice of the members who posted on your thread or use the Search button. This topic has been covered waaaayy too many times.
Dee
