rmezz13 wrote:i am wondering if you can get to it from underneath? just by removing the air dam under the car and get to it from there.... other than that, it makes it a heck of a lot easier to remove the bumper &/or fenders if you remove the wheel...
Thanks mezz, very helpful
maximus108 wrote:I did that mod to my car too!I didn't take off the bumber, the tires or even raise the car.
1. Just remove all of the bolts that hold the bottom, front, plastic thing.2. Once that is removed snake your arm into the place where the reflectors are housed, (your arm will get a little scraped and bruised).3. Remove the 2 screws and wiggle/pop the reflectors out.
-You could also try going through the wheel well, that sounds like it might be easier.
The clear reflectors will look clean on your car because it's black.-You might also want to replace your front, orange turn signals to clear ones so that it'll all look clear white, (that's what I did).
thanks to you I saved a lot of time and headache. If people knew how easy it was, more people would probably do it.
So I got my reflectors done. Did not have to remove my front bumper or front wheels.
Watermelonwarrior wrote:zerothread/359270
Ill be doing this tom to replace my front bumper. I wish I had bought the clear ones since im already putting all the work in.
Thanks melon but this thread is more for people who want to modify their headlights.
