Clear'g "Ox-Sens Incomplete" code fr NYS emiss test.
MISTERCUE
Car: 2001 NISSAN PATHFINDER SE
Hello all! New to this forum, old to Nissan! :) Prev owner of a Max, Sentra, Path 98 & now own a Path SE '01. My prob? "Serv Engine Soon" lite on & mechanic had it re-set
& lite off. Took it in 4 NYS inspection & failed due to emission fail. Exhaust sys completely rotted out & had it replaced. Back 4 inspection & "catalyst, Evap system cleared & complete" but Ox sensor reads incomplete. Mechanic states to drive vehicle for 60 or so miles for it to re-set & drove aimlessly :crazy: for over a 100mi yet last & final reading for emission test states "Ox-sens" incomplete. Mech says that I need to drive an addtl 20-30 miles in "smooth" hi-way traffic in order to re-set sensor for "complete" code to appear (I told Mech that in NYC, there is NEVER any smooth hi-way traffic)! N-e way, is there anything I can do to "speed" along the completion process of the last & final portion of the emission test which computer still shows "incomplete"? Thank you!
ARKQX33V6
Are you talking about a heated O2 sensor, if so check the heating circuit. By the time the coolant sensor is warmed up on the engine it will take about 5-10 minutes for the transmission heat sensor to be warmed. In zero weather the overall time for a complete warm up is about 10-15 minutes so check your temperatures, then scan.
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
What's the numeric code? It will be something like P1234.
When the SES light is reset, you have to have a certain amount of driving afterwards for it to pass smog test. That's to keep
you from resetting in parking lot at the test station. I know that two thirty-mile trips with an overnight cool down is
enough, as long as the problem does not reoccur.
