rudee023 »
https://forums.nicoclub.com/rudee023-u4970.html
Wed Aug 03, 2005 8:26 pm
You can run electric fans and ditch the stock fan and shroud. You could also run a small filter on the "T" from your valve cover going to the intake. On the other end remove the stock baffle and just run a heater hose down to the block. If you don't care, remove everything AC related. I remember my old setup was 100 times easier to work on than my other friends cause it was tidy and I had so much room.
