elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Tue Sep 30, 2003 8:42 am
I really dont think it will improve that much performance.... I could be wrong, but I cant see how it would make much of a difference.......
What you do it for is to clean the dirt out, because the dirt getting into the cylinders makes it wear faster.......
Anyway, to clean the plenum, best thing to do is get a 6pk of carb/TB cleaner, a rag, and go nuts...... Look into getting those disposable shop rags, or use ones you dont want back, because you wont want them back after your done!!! I consider myself spoiled, since I have access to an industrial parts cleaner......!
Valve covers are a GREAT job to do..... You should do both while your in there..... If you are even close to needing new plugs, now is the time.......
Also, Id recommend taking pictures of the heads with the covers off, so we can see what they look like (like how much wear has occured)......
Releasing fuel pressure is easy..... Just take out the fuel pump fuse in the passenger cmpt block, crank the engine a few times........
