Didn't have any luck with the search.
Thanks. That does make sense not to use alcohol on what's left of the clear. Im hoping not to incorporate any water if possible. My cousin said he used purple power and had a guy he worked with power wash his bay. His car is in much better condition than mine is and hasn't sat as long either so he didn't have to worry about exposed electrical parts, like wires and clips.itsa300zx wrote:If you are using any type of brake clean, test a small area on the paint first. I would recommend simple green, may take a little longer soak time, but it works and 100% safe on paint.
