nsrZ32 »
https://forums.nicoclub.com/nsrz32-u20984.html
Sat May 26, 2007 9:20 am
Ok, the first step towards cleaning up a nasty engine bay is a quality engine degreaser, pick up a couple cans. Go ahead and spray it down with it and let it sit for a few minutes to eat through stuff. Generally I have the vehicle running at this time.
Second would be...spray down the engine bay with hot water to rinse everything off and flush the junk out of the engine bay. Have it running still. You might need to do the first two steps a couple times to get things loosened up and clean. Once done with this step, you can turn it off.
Third...I generally lift up the vehicle and pull all the splash shields off the under side of the engine bay and clean the under side with some brake parts cleaner. There's always tons of caked up grime and all the stuff you just cleaned off ran down there anyway. On Steph's 240sx I went through like 5 cans of brake cleaner on the under side of the engine and bay.
Fourth...I go back up to the top side and usually use a product called dissolve all (or something milder like simple green) to break up all the deposits of oil/dirt/grime/whatever that are left after degreasing. You need to do some scrubbing and elbow grease on this step.
Fifth....I usually fire the engine back up and spray it down with hot water.
Sixth....depending on how your paint is on the fenderwells and firewall, you might want to use some Meguiars paint cleaner then polish and wax it.
Seventh...get down in all the little places, use old tooth brushes, Q-tips, tooth pics, lots of rags and towels. Make it look new.
Lastly....spray down the engine bay with a silicone based engine dressing. You'll probably need to do a few applications as the old rubber and plastic that hasn't been shown love in years will soak it right up.
After all that....you'll have an amazing engine bay that looks like it was never neglected. Its a huge turn around and shouldn't cost you much money at all.
It takes a lot of time, but its well worth it. Ask anybody who has seen the clean up work I do....second to none
