cleaning the alternator
ceniack
Car: 1992 240sx Coupe
1993 JDM Nissan Caravan
2011 Subaru WRX STI Hatchback
2012 Subaru Impreza Hatchback
just a quick question (i know this probably sounds weird and anal retentive) but i am in the process of cleaning/painting my engine while it is out of the car, and was just curious if any of you know of a good way to clean up the alternator (mainly the outside casing, but the inside would be nice to clean as well).
also going to clean the starter, any suggestions on that?
-terry
davidricardo86
Car: 1992 Nissan 240SX SE
Hmmmm... yes interesting. The way i would go about it would be by disassembling the starter/alternator. Try and remove as much of the the key internals like the armature, brushes, bearings, etc. or vice versa for the other. Remove anything that can be removed and try to cover what cant be removed or find a way to not let it get paint overspray.
Actually i think i might try this myself since you brought it up.
nocwage
On a side note, if our alternator dies which one do we replace it with??
davidricardo86
I would have it rebuilt. Take it to a place that still rebuilds alternators and starters. Allthough these places dont exist in large numbers, some are still available. They will replace some of the common wear components inside like the armature and brushes.
That or try and find a way to get your hands on a new or rebuilt one.
mrzabala
Car: 93 Nissan 240SX SE Hatch
Before you do any cleaning and such. Have the starter tested and if possible the alternater too. If there good than a good way to clean the outside casting is simple green. As for internals of the starter you want to be careful if you take it apart since its harder to put everything back together do to the magnets and the coils inside. I just used a shop towel to clean the inside then used a brush to take out any of the grim off in the corners. Then I think I used a spray lube on some of the parts but its been awhile. Goodluck with yours.
NismoGreg
Car: '93 s13 fastback se, '87 200sx se v6,'91 integra ls
I used some electronic parts cleaner in a spray can from autozone and it cleaned my alternator pretty good.
bentvalves
Car: 89 Silvia K's
I had mine rebuilt, and in the process, it was glass beaded. Looks brand new again, im pumped.
ceniack
how much did it cost to have it rebuilt?
