Cleaning out the 240!
CRyan
Car: 1997 Nissan 240SX
Well seeing as my car will (hopefully) be running by the end of the week - I decided I'm going to clean out the WHOLE car.
I have not taken out the carpet - But I'm shampooing it in the vehicle - It already SMELLS like a newer car
Anyway - I was pulling out the junk in my trunk. . .
The stuff in the trunk of the 240 and came across some Dynomat material. The stuff for deadening sound and what not, and I want to remove it.
The only way to get it out is pull on it? I'm limited to chemicals because I'm at my house - but i do have acetone.
Anyone have any better ideas - I'll come back in shortly to check - but onwards to the seats!
zach-Ka
Car: 1990 240sx (SR)
I have always seen it done with dry ice... so idk...What shampoo are you using?
CRyan
zach-Ka wrote:I have always seen it done with dry ice... so idk...What shampoo are you using?
I'm using a carpet cleaner I got from when I was working at Nissan dealership. The guys that clean the cars in the back are pretty cool - But its made by turtle wax and there is a brand that is relatively the same - Its the turtle wax OXY power out carpet cleaner - It comes with some little brush to get the deep stains out - Its working fantastically.
And thanks for the info on the dynomat. I'll have to figure something out - Because I don't know of anyone who has dry ice.
zach-Ka
Some grocery stores do. I used that stuff on my s14 seats. Good stuff. Is it the stock sound deadening material or actual dynomat?
CRyan
zach-Ka wrote:Some grocery stores do. I used that stuff on my s14 seats. Good stuff. Is it the stock sound deadening material or actual dynomat?
Actual dynomat - apparently the owner before me kept the car completely stock minus the sound system.
Which is probably why the trunk is a bit loose.
zach-Ka
O in that case peel it off and use something to the effect of goo gone to get what is left over off. That should work. Sorry I thought you were talking about the stock stuff.
S13Joe
Car: 92 Coupe
heat gun? i dont know how to remove dynomat but i would try that.
zach-Ka
Heat gun would help that was my arsenal when I removed the fabric off my door panel.
CRyan
zach-Ka wrote:Heat gun would help that was my arsenal when I removed the fabric off my door panel.
Its done now ha - Thankfully I just started pulling and it SLOWLY peeled away.
It was one piece left that was about a 2' by 2'. It just looked ugly - Think I'm about to attempt to put the belts back on. Mind you - I messed up and removed the belt tensioners
Might be fun. Or a PITA. O well - I'm just excited my car is soon to be driveable. And for all that care I got the wheel bearings pressed and ready to go.
Is the dust shield really "required". Mine got a bit bent up in the process of removing the hub assemblies.
zach-Ka
I dont think so. I know when people put z32 brakes on they do away with them...
Razi
Car: Moo
It keeps water and dirt out of the rotors, as long as it isn't missing, it should be fine.
Mine is completely flattened out because I had to accommodate for my Q45 brakes.
CRyan
Does no one here have a job?!?! haha - thanks for the quick reply guys!
I hope to work all through the day and see how far I can get - Trying to find how to run these belts now and make sure I'm not missing any bolts from the removal of the belt tensioners
zach-Ka
Gotta love third shift!
SirSilvia
Car: Sold both my babies
what has two thumbs and gets paid to be on nico... this guybut I was wondering, when you peeled that sound deadener off, did it leave any gummy or sticky residue?
CRyan
SirSilvia wrote:what has two thumbs and gets paid to be on nico... this guybut I was wondering, when you peeled that sound deadener off, did it leave any gummy or sticky residue?
No tacky or gummy feeling that I felt - But its cold so it probably pulled everything up.
Granted it looked like it had been in there for ages ha
SirSilvia
good to know, thx
