Cleaning of a cooler of the conditioner.
CBR
Car: Infiniti J30 1994
A problem that at inclusion of the conditioner very poorly blows cold air. At service station all have checked up and have filled with a coolant. Have told, that cleaning of a cooler is necessary. Friends, prompt how to reach a cooler of the conditioner which is in interior? What it is necessary to remove and turn off?
driverdriver
Car: NICO's longtime resident Canuck!!!
Have the AC technician do a leakdown test first to ensure that there isn't a leakage of freon before starting to change the AC components.
yodawill2000
Car: 94 Infiniti J30
Are we sure he's not talking about the heater core??Cant imagine needing AC in Moscow about now.
StevieRaySTL
Car: 1990 Infiniti Q45 w/ Nico ECU
1993 Infiniti J30 w/ x-flow
1997 Toyota Landcruiser
-- Is it even winter there right now? I don't really know if it gets warm there in summer, but seeing that it's on the other side of the globe and all, it may not be late fall in Moscow. This is all kinda interesting to me, maybe CBR will tell us what the weather is like and if hot or cold air is the issue.
littlewillie
Modified by littlewillie at 10:21 PM 12/23/2007
CBR
Now at us +32-35 F.Problema with the conditioner exists since summer. In the summer machine used a little (basically went by a motorcycle), therefore especially was not engaged in the decision of this problem. Now there is time, would like to clean a cooler of the conditioner all the same. Asked here about this radiator: the Problem that I do not know as to it to steal up. Prompt sequence of disassembly to steal up to this radiator.
littlewillie
Modified by littlewillie at 10:22 PM 12/23/2007
yodawill2000
Sure looks like that would be a long weekend job !!Under dash stuff is never much fun.Even when your as small as I am ! lol
CBR
Yes, it is similar easy to not reach the evaporator Here a key phrase:
It is necessary to remove the instrumental panel
Gerardjg
Car: 2007 Cobalt LS
2011 Hyundai Accent
2016 Kia Optima
I cleaned my interior coil a couple of years ago. I did not remove the coil. If you remove the glove box and the panel below the glove box you can then loosen up the plastic case or the blower(I do not remember exactly) and vacuum the fins of the radiator on the intake side. It was a while back but I did find the info here on NICO.
I think I used this http://www.q45.org/cleanevap.html as a guide but the Q is not exactly the same
J30 Drawings
Modified by Gerardjg at 2:02 PM 11/29/2007
Modified by Gerardjg at 2:22 PM 11/29/2007
Modified by Gerardjg at 3:48 PM 11/29/2007
Gerardjg
Car: 2007 Cobalt LS
2011 Hyundai Accent
2016 Kia Optima
Here are instructions on removing the blower motor
zer...91214
Modified by Gerardjg at 2:20 AM 11/30/2007
