joestrummer77 »
https://forums.nicoclub.com/joestrummer77-u90076.html
Mon Feb 25, 2008 2:36 pm
RE: Exhaust leaks
May be the exhaust tubes located at front of vehicle, but I think it's only 2002/3 models.... There's a TSB for this....I believe the part# for fix is #20711-5W90A. OPeration code FX09AA.
Mine was HORRIBLE, and did not manifest itself until after about 9 months (I bought a 2002 QX$ used in December 2005).
After the fix UNREAL difference. The seams/welds on the front exhaust tubes crack causing the issue. Again, not sure is this TSB applies top yours, but hey it's worth a try. Hit Edmunds.com and check TSBs.
Good luck,
Nick
