Cleaning IACV without taking it off?
AR31TU
I remember reading a writeup on pulling a hose or unscrewing something to spray carb cleaner into, to clean out the IACV, instead of taking it off, but I can't seem to find anything under recent or archived threads. Anybody know how to do this?
Thanks!
180fan
Car: 89 fastback
spraying into the hose from the intake piping to the iacv isn't the most effective way, I've discovered. To get the best clean it should be removed and cleaned.
SuperJoe240
Car: 1989 240sx
what is the IACV and what does it do?
sds14240sx
Car: 240sx
iacv means idle air controll valve its a sensor
redeonx
Car: 1989 nissan 240sx
were is the ivac located on a 1989 240xs hb. 2.4 single cam
pease email me at [email protected] ty
180fan
Car: 89 fastback
back of the intake manifold. easy to get to unlike the dohc ka's and the sr's.
green91
Car: s13
It is not a sensor. The idle air control valve allows air to bypass the throttle plate when it is closed to regulate enough air for the engine to idle
drifterz73
Car: 1989 240sx coupe/w auto and 1989 240sx f/b w/ man
you have a pic of the aicv and how easy it would be to remove car is hesitating and runs like crap in the morning... please help
vancouverbc
Car: 1991 240sx
http://www.geocities.com/Motor....html
there are some threads on this in past couple days. it was easy for me to remove mine on my 1991 240sx. lots of things cause hesitation , though.
zerothread/174196
