cleaning headlights (sort of)
chmercer
my headlights are yellowy, i have searched and found to use nail poilsh remover to clean them, but how exactly do i get the lens off to clean the reverse side? i popped off the 4 metal clips but there is rubber sealant all the way around my light? if i pull this out will the bulb leak? or am i going about it in the wrong way? thanks.
LaureltheQueen
lol.... I know that the acetone works well to clean headlights, but I was looking up TSB's on the s14's, it says DO NOT PUT ACETONE ON HEADLIGHTS!!!! Apparently they're supposed to crack if you get it on them. :shrug:
Touchdown038
Car: Computers, cars, sports
Here is a guide to de-yellowing your headlights. Thank stickgoat for it.
'91 240sx
would this work on an s13's flip up lights, because my lights are so yellow and its so hard to see at night
chmercer
so i take it you dont have to clean the inside of the lens at all?
Holisticbeatz
'91 240sx wrote:would this work on an s13's flip up lights, because my lights are so yellow and its so hard to see at night
Buy a pair of these:
'91 240sx
good looking out, i think thats where my moneys going
JohnI3laze
I used Mothers plastic polish on the outside of my lens and they look a lot better. I didn't even remove the headlights, I just put newspaper around them and went at it. There is still some pitting in my lens but they look a LOT better. I let my friend use it on his DSM after and his lights were way worse.(think Yellow) After that I really saw what this stuff can do for lights. His lights look dramatically better now. Not brand new looking, but significantly better than it was.
Structure240sx
u should have to clean the inside but if u really want to use a heat gun or hair dryer to melt that rubbery suff then jsut push them back on. my friend did it on his civic to "clear them out". it worked
