qship96 »
https://forums.nicoclub.com/qship96-u3104.html
Sat Dec 15, 2007 11:19 am
Get a can of Gunk or 2,spray warm,not hot engine-let it dwell for 5-10 minutes and rinse well -easiest to do at the local coin wash bay-then go for a long drive to dry out engine and all connectors.Might need to start with brake-cleaner on cold exhaust manifolds if they are stained from leaky valve cover gaskets.
I would skip spraying down the engine with a protectant when done,as it only causes dust/dirt to stick to everything....if you must,just apply protectant to a small sponge and go over hoses and all rubber/plastic bits to add some bling.
