Cleaning Engine Bay
unknown007
Car: White 1993 Q45 (G50)
Whats the best way?I know and hear sea foams bad anything else that would work?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Searching on previoius threads works fairly well.
Best is elbow grease.
AlabamaDan
Car: 2015 Infiniti Q70
1998 Infiniti QX4
I agree with elbow grease. I use brake cleaner for the bad spots on the block and such. Be careful with simple green and other harder chemicals. I use Window Cleaner and cloths.
unknown007
These are to clean it out just where you see right?what about the gasket covers (or what they are called)?I really need to clean underneath the Spider manifold because the radiator cap it had before didn't seal.I bought a new one though.So let me know i'll be looking for elbow grease i guess.
Just remember isn't sea foam for the engine internals etc?not the bay?
qship96
Car: 1996 Infiniti Q45
Get a can or two of Gunk engine cleaner at your local auto parts store-about $5 per can or so- it is basically a kerosene type degreaser....spray all over a WARM , not hot engne, use an old paintbrush to scrub nooks & crannies and really dirty spots, close hood and let simmer for 10 minutes then hose off and run car for 30 minutes or so to dry off engine.
Resist the urge to use tire/rubber dressing on the now clean hoses and black plastic items under the hood- while it will make everything pretty and shiny new looking short term, within weeks it will look bad due to the dust/dirt sticking to everything.
unknown007
how can i get under the manifold?
qship96
Just aim the can of Gunk under there, it sprays a good hard stream.
unknown007
qship96 wrote:Just aim the can of Gunk under there, it sprays a good hard stream.
And then just hose it down in that area right?dont wanna mess anything up you know?
qship96
Yes! I spray the cleaner everywhere under the hood,let it sit for 10 minutes or so, then rinse with a hose.....run engine for 30 minutes afterwards to dry engine
unknown007
qship96 wrote:Yes! I spray the cleaner everywhere under the hood,let it sit for 10 minutes or so, then rinse with a hose.....run engine for 30 minutes afterward to dry engine
Just came back irritated from the ****ty *** drive. Trucks need to level their fogs and head lights first of all and 18-wheelers shouldn't speed up when a driver is entering the freeway and is far from them.Just because of them I couldn't see smack and almost ran a Mercedes off the road.Weird.
Anyways back to the subject.So just spray everywhere?What about for the big big chunks?Also any idea how to clean exhaust vapor from differential?Thanks qship96 you the best!!!
qship96
Spray everywhere and use an old paintbrush to scrub the heavy dirt areas, then hose off.
The differential can be spray cleaned with brake parts cleaner, again use a brush if needed on really built up dirty spots.Get 2 cans, they are only a few bucks each and clean really well- no need to rinse with water when done as it evaporates quickly . You might want to unscrew top fill plug on your differential and check fluid level to be sure it is full and not leaking if you are seeing a buildup of oily dirt on differential -
unknown007
qship96 wrote:Spray everywhere and use an old paintbrush to scrub the heavy dirt areas, then hose off.
okay sure will thanks very much.
Meatro20
Yep, spray the crap out of it with degreaser and hit it with a brush. Just like anything else, you only get out what you put in.
unknown007
Meatro20 wrote:Yep, spray the crap out of it with degreaser and hit it with a brush. Just like anything else, you only get out what you put in.
I've tried two types of degrease and nothing happened.If you look at my engine now it's super clean but not the part or as i want it.Today i put in my old hood struts that for some reason were still very good.My hood was open for like 1hr 30minutes or maybe less and everybody who saw was like DAMN what a clean *** engine.
Oh peep this for people selling parts i maybe need the things that bolt into the firewall and clip on the struts.So if anybody got them send them my way asap>A fair low price would be best or at least until i get more money.
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Can you show what what you mean in a picture or describe a little better?
unknown007
ppastos wrote:Can you show what what you mean in a picture or describe a little better?
Not at the moment. But open up your hood and look at the part attached to the firewall where you hook the struts to.Its dark gray.Now you know?lol
datsun2401972
Car: 90 Nissan 240SX XE coupe
Did you ever find any elbow grease?!
unknown007
datsun2401972 wrote:Did you ever find any elbow grease?!
No haven't got the time to yet.School you know?I'll post once i do.
datsun2401972
yeh, it's a special formula....pretty hard to find actually.
unknown007
datsun2401972 wrote:yeh, it's a special formula....pretty hard to find actually.
Nothings hard to find if you search ha.
unknown007
What elbow grease should i get theres so many?
Theres some elbow grease on your elbow ha try that lol.
Q451990
I find that elbow grease is enhanced when combined in moderation with the following substances:
1) Beer2) Bourbon3) Scotch4) Cigar
Heath
Infinitiguy19
Hey do you mean that little clip that holds the end of the hood piston in?
datsun2401972
yup, the hood piston.
If you can't find that clip just get a skyhook, it'll work fine.
unknown007
Lets see if i can find a pic of a q45 engine bay.
Searching. . . . . .
There understand?
That my engine ha
aces805
Car: 1994 Infiniti Q45t
Your engine looks clean enough to eat off of!
Infinitiguy19
Sorry but still can't tell what your looking for, perhaps zooming in on what you need would help
LeroyBrown
Car: 1995 nissan 240sx s14 blacktop
if you wana clean it use the high pressure wash at the car wash.. if you want to make i look good and shiny i use tire shine the blackmagic foam one.
unknown007
LeroyBrown wrote:if you wana clean it use the high pressure wash at the car wash.. if you want to make i look good and shiny i use tire shine the blackmagic foam one.
I used that on the pic.But the pic is very old.
My engine top is clean but not under the spider.
Ight well I'll get the camera out tomorrow.
datsun2401972
homes...I'm just foolin with ya. Elbow grease just means that you use your hands alot...maybe you already knew that...
