Cleaning BBS wheels
AlabamaDan
Car: 2015 Infiniti Q70
1998 Infiniti QX4
Those BBS wheels look great, but they're a PITA to clean. What do you guys use? I've used a spray on stuff, but it still requires cleaning with a toothbrush (yes an old one) to get them clean.
Thanks,
91QAZ
Car: 91 Q45
I use the toothbrush method too. Except that I use my wife's toothbrush . Shame on me for even saying that .
Rex
Car: None
Is there some kind of nylon bristle brush attachment you can use in a drill?
Maybe make something out of a few old tooth brushes??
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Toothbrush with mild soap/hot water solution and a lot of frenetic action from all possible angles.
If you use a wheel cleaner, know it will mess with any cadmium plating on your hubs or disc rotor hats, and may break the clear seal if you get the wrong kind.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
THey sell brushes at autozone that are like cones.. you insert them into the little "holes" and move it around...
I used a $3 Eagle One wheel cleaner brush (duh) from PepBoys...
Has a handle and some soft bristles on a large wire loop (that you can bend as needed).
Think i still have it laying around, no need for it anymore.
Alan
Car: Cars, cars, scooters
Wheel wax. I have a friend who is seriously into polishing his BMW, I borrowed his. The BBS stay cleaner a little longer and the brake dust scrubs off with less work. Still, it gets down to "frenetic action" and some kind of brush.
Alan
