Q451990 wrote:So your temp sensor is following the trend that the FSM says it should (lower voltage with higher temperature)
Yes it does follow the trend.
Q451990 wrote:
I would suspect it's one of those programming glitches, like the difference in displayed timing vs. actual... I would check it with a good VOM meter before you start replacing parts.
Heath
I sure hope so but at the same time as Q45Tech said the Laptop Consult displays the same stuff as a regular Nissan Consult.
Peter at ECU Talk might be able to explain more about the timing annoyance but I did hear him say that american Nissan's display timing differently.
I could unplug the A/T solenoids harness connector and test the correct pins but I have a feeling that that would give me the same reading as the Consult.
Thank you Peter and Heath for responding!
