Khronik wrote:Due to a possible tps or maf issue im going to do some cleaning and checking of connectors
Im guessing I want the battery disconnected while doing this but my question..
Is it ok to start unplugging everything and using deoxit/progold sprays+dielectric grease on all connectors?
or is there no need to use dielectric grease after using deoxit and progold?
I read somewhere that some of the connections are very thin and dielectric grease can actually cause problems
dont remember where I had seen it and cant find it again
I used a bunch of stuff, Radio Shack contact cleaner, emery cloth, wire brush, small screw drivers, brake clean, etc. Basically, get all of the green off of every connector. Then apply di-electric grease on each contact of each connector. It helps seal out the moisture. It won't interfere as long as the connector makes good contact. If the connector connects loosely, tighten it up. You are just avoiding a problem down the line.
Be careful getting the connectors off the injectors, IACV, MAF, PTU, CAS and all of the ones that have the metal clips. They are usually very brittle and break easily. Also, don't be surprised if all of your coil pack connectors break when you try to remove them. If they go back on snug, you will be fine.
