Cleaned the Throttle Body
merlinq2
Car: 2007 Infiniti M35x
As part of my futzing around the garage regiment, I cleaned the throttle body on my M. After I had taken the throttle body off and leaned it, I re installed it and took the car for a spin. The car has not moved since. This morning it was a bit cooler, and I noticed the idle was a little higher than normal, even after the engine had warmed up I found the idle to be just under the 1K rpm mark?
Is that normal of do I have to reset the ECU?
EniGmA1987
Car: '06 Infiniti M35 Sport
the "drive-by-wire TBs" on the newer Ms and Qs have very sensitive actuators and sensors that can be damaged so TB cleaning is NOT RECOMMENDED.
One of the things you can easily mess up is your idle speed. You will need to perform a new idle air learning procedure. IDK how to do that though
merlinq2
Thanks for the info, pretty scary note, anyway, I will reset it and see what happens. If doesn't work I guess I will have to replace it. Funny thing is that the TB wasn't overly dirty and all I did was remove it and use a micro fiber cloth to clean the loose soot out if I did not use any chemicals or sprays. Car runs fine and starts great, just idling a little higher than it was before say less than 100 rpm difference- do you know what the idle speed should be?
uh2
Car: 2006 M35x
I believe it is 650 RPM +/- 50. This is at normal operating temperature..no additional load on the engine (lights, AC, etc).
I hope the idle is the least of your issues....cleaning the throttle body can lead to its replacement. I just had mine replaced after a cleaning by a dealer. After the cleaning, I noticed the idle was extremely high so I performed the idle learning procedure. It worked, but after that the car would throw codes and go into limp mode.
Good luck.
cruzad3r
Car: 2006 Infiniti M35x fully loaded
what is the "idle learning procedure" and how can one do this? Since you posted you did this yourself, can you share the knowledge?
Also, what chemical did you use to clean your Throttle Body? The number one issue of killing your TB is when you actually touch the butterfly valve, not cleaning it.
JM45
Car: 2006 M35
merlinq2
uh2 wrote:I believe it is 650 RPM +/- 50. This is at normal operating temperature..no additional load on the engine (lights, AC, etc).
Good luck.
Perfect thanks, took the car out at lunch time and the idles settled about 650 to 700 rpm, all looks normal, but thanks for the quick responses...........
merlinq2
cruzad3r wrote:what is the "idle learning procedure" and how can one do this? Since you posted you did this yourself, can you share the knowledge?
Did not use any chemicals worked a microfiber cloth into the front and back of the throttle body and just rubbed the surfaces. I did push the butterfly valve a few times. I will note that I did remove the tb from the intake, unplugged the connection.
Thanks
