FTRS14.5 »
https://forums.nicoclub.com/ftrs14-5-u3490.html
Mon Mar 15, 2004 7:38 pm
XCrunner19420: Dont know if your replying about the valve cover paint, but I just used some High Temp paint from the local auto store. Sanded the whole down to metal, then applied about 4 coats of High Temp Primer, then 4 coats of the Blue and then 4 coats of the High Temp Clear. I still need to wet sand and buff it, but it turned out fairly good I would say.
180fan: I used Castrol Super Clean (Purple bottle and can be bought at Wal-Mart for $5 for a gallon). I used about a 2:1 ratio of it and had a small brush. Only needed one application for most of the motor (I drenched the motor with the Castrol though) and scrub what I could. Then used a pressure washer to get everything else out.That Castrol is the ever!! Better than Simple Green!!! Highly recommend it to everyone. I should be painting the bay sometime before the end of the month so I'll be posting pics of that process as well.
