clean injen air filter
All things Altima Coupe.
soxypoo
Car: 2008 Nissan Altima Coupe 3.5 ( gone )
2010 red G37X w/sportpackage
2012 sentra ser spec v loaded
i tried to use the search but i can;'t find my answer....
do i clean the air filter with soap and water or just water and let air dry over night ???? do i need to apply oil like the one from injen website " pro-tech charger kit " ?????
thanks
SHIFT_COUPE
Car: 2014 Infiniti Q50 AWD
Go to your local autoparts store and purchase the K&N recharger kit. Same as what Injen has. Don't use soap and water! The K&N kit comes with cleaner and oil.
soxypoo
ok thanks i have the filter sitting on the counter and i was waiting for a reply from here lol thanks
beeristasty
Car: 07 Altima 3.5 SE
What color is your filter media? If it is red,then it is the type that needs oiling. If it is blue, then it is the dry type.
SHIFT_COUPE
Its Injen so its red :)
SneakyFish
Car: 2008 Altima Coupe 3.5SE CVT
beeristasty wrote:What color is your filter media? If it is red,then it is the type that needs oiling. If it is blue, then it is the dry type.
i dont belive that is entirely correct. i ordered a second dry air filter from stillen and it came as red
beeristasty
I know you can order them with (dry) Amsoil blue filters. At least they're blue on Amsoil's web site.
soxypoo
mine is blue .....
srwong
Car: 2009 Altima Coupe 3.5 SE CVT
soxypoo wrote:mine is blue .....
mine too
lGonz
Buy the injen air filter cleaner on ebay.
Comes with the cleaner and oil..
your not supost to use ur filter without oil,
and if you over oil it messes with your sensor
SneakyFish
how bad is it if i oil a dry filter?
soltys
Car: 2008 Altima Coupe 3.5 SE 6-speed (Satin White/Black)
2009 Rogue SL AWD - (the wife's)
SneakyFish wrote:how bad is it if i oil a dry filter?
It's not good that for sure. The material in a dry filter won't absorb the oil and it can get into you intake tube and coat you MAS. If enough oil gets on the sensor, you have everything from misfires to a stalling engine and in time, the MAS will have to be replaced. (not a warrentee item)
My AEM intake has the dry filter and it just need the AEM "soap" bath, a cold-water rinse and air dry ... done.
The color of the filter does not determine if it's an oil or dry system. There are red and blue oiled filters - it's all determined by the kind of oil that each system uses. My dry system is more grey then anything.
beeristasty
About a week ago I was going to get another dry filter for my intake, and I stumbled across the blue Injen/Amsoil filter. Did a little research on it, but in the end I decided to stick with another AEM Dryflow.
I would recommend anyone who is confused about cleaning their blue injen/amsoil air filter (It will say Injen/Amsoil on the top of the filter) to read their instruction manual before they mistakenly oil their dry filter. Again, the red injen filter requires oiling after cleaning. So in this case of these Injen filters, color does matter whether or not it requires oiling.
