clean engine has me laid up.
blinkshome
Car: 95 240 ka24det
i drove my car home from work after detailing it to a "t". popped the hood and washed the motor down with a couple of cans of carb cleaner. when i came out the next morning the car would not start. i blew out everything and let it sit for a couple of days. still would not start.
i replaced:-entire dizzy assembly-plugs-wires-maf
the car has good spark, fuel and time. im baffled. am i missing something that could have been torched by my cleaning method. is there a ignition control unit on the 95 240s. its been almost two months now and im considering taking it to nissan.
any ideas out there. thanx
WDRacing
Have you tried pulling the codes? Have you checked the fuses and relays? When you were cleaning, did you unattach any of the wiring by mistake?
WD
blinkshome
Car: 95 240 ka24det
the cpu shows no codes. relays as well as the fuses all show good. everything i can physically touch or test seems to check out. im overlooking something simple. i imagine something tripped up or got fried. trying to find it is what sucks. theres not much left.
