Notwobuckbear wrote: Does the 3.5 have hydraulic 'lifters' that take the slack out of the valve train so adjustments aren't needed?
So you live with a little noise at startup or have you found an oil filter combo that helpsChris.m wrote:Notwobuckbear wrote: Does the 3.5 have hydraulic 'lifters' that take the slack out of the valve train so adjustments aren't needed?
And I've looked into getting the valves adjusted and it's just not worth it.
I'm no expert and I get your point, my thought is that an oil that maintains higher viscosity during heat will drain back more slowly, clinging to part for the next start up. When i did the oil change after buying the car, the oil was very tin and drained quickly. I'm sure gas dilution has some effect that way. 10-40 for my spring-summer oil change and 5-30 for my winter. As I understand it, a multi viscosity oil tries to stay at 30 weight acting as 5w would in cold and a 30 or 40 wt when hot, but stabilizing viscosity around 20-30 wt. What is your take on it. Supposedly tighter engines and the drive for fuel economy begs the lighter oil, as well as advances in bearing and oil technology.Towncivilian wrote:Hot ambient temperature does not affect engine oil temperature significantly. The cooling system keeps the operating temperature within range. A 5W30 will provide better cold flow and sufficient protection in all temperatures and seasons. Of course, if you live in a hot climate, 10W30 or 10W40 are okay to use, but 5W30 would still be thinner at startup even in 95F weather, which still counts as a "cold" start for the engine.
