pstarbard »
https://forums.nicoclub.com/pstarbard-u250759.html
Mon Feb 15, 2016 7:08 am
Thanks for all the advice. I checked the fuses from the links in the first reply and they were fine. Next, I checked the belt tension and it seemed a bit loose but appeared to be turning all he pulleys. I charged the battery and tightened the belt tension and all appears to be fine now. Probably put about 30+ miles on it since doing that with no problems. It was 0 degrees F +/- a few degrees all weekend so I'm glad I didn't have to change it.
Thinking back, the old battery failed and wouldn't hold a charge. This was after I changed the belts. My guess is that the belt tension wasn't high enough and, as a result, the alternator belt wasn't turning reliably all the time. And, the sudden drop in temperature aggravated the problem by making it harder on the battery and contracting the parts just enough to make the problem less intermittent.
