USDM_OneVia »
https://forums.nicoclub.com/usdm-onevia-u6319.html
Sat Nov 22, 2003 5:01 pm
Terminology is a bit backwards.....
The KA clutch disk will work on a CA flywheel. And then the KA pressure plate will bolt to a CA flywheel and cover the disk. The only thing you have to do is redrill the pressure plate. The are physically the same size, but the mounting points are a tad different.
Or you could go either of the two easiest routes known to man. Spec Clutches makes RWD CA clutches, you can buy one from them, or you can buy my Spec Stage 1, 285 to your door and will hold 290 ft/lbs of torque too.
Joe
