Clarification on ka24de swap
spyro187
Car: 1990 240sx, ka24de swap, gutted rear, 17" motegi's, msd coil, injen intake, electric fan
I have been searching like crazy in the forum for a few things and just want some clarification. I have a 1990 240 manual. I have a ka24de motor from a 92 to put in.
From what I have read I will need the following:engine Wiring harness ( from a ka24de manaul only )ECU ( from a ka24de manaul only )Gauge clusterA/c LinesP/S Lines
My main question is, is this an accurate list and does the wiring harness and ecu have to be from a car that has a manual trans.
Also i've read that the new wiring harness may not connect to my dash harness correctly.
Thanks for any info you have.
medapimp4aday
Have fun i just am finishing up my stock ka24de swap. First swap and its a great time!
spyro187
I'm still trying to find all the parts I need to drop in the new engine. Can you give me any insight into my original post? Also, did you have any specific problems I should watch out for.
medapimp4aday
i just did the ka24de replacement, i believe you need a gauge cluster for this swap everything else sounds correct
