EazyBreazy wrote:This one on the other hand has tweeter screens in the a pillars. So does this mean that i have the 6 speaker option and have the factory amplifier.
Most likely yes... but there are a few very easy ways you can tell to be 100% sure.1. Does your car have the factory CD player built into the main head unit? The Premium audio package had a CD player instead of a cassette player if you've got the CD player then you probably have a-pillar tweeters and a factory amp.
2. Open your trunk and look under the rear deck lid (the area where the rear speakers are located) The factory amp is made up of 2 metal boxes that hang from this area with a plug going into each box... you can't miss it.
3. remove your a-pillar cover and look for the tweeter under the front grills. This is easy to do simply find the edge of the plastic pillar cover near the top of the door gently pull down right at the end of it until it pops off, then work your way down the windsheild until you get to the bottom and it will come right out. Once you've got the cover off you'll have a much better idea of how much space you've got to work with for an aftermarket tweeter.
EazyBreazy wrote:Also Im thuroughly dissatisfied with the factory speaker system but i don't want to put a sub in the trunk. My plan is to run an Alpine SPR component set in the front doors 6 1/2's and then I've thought about doing the rear speakers a little differently. I want some base, but generally from my experience 6 1/2" speakers arent capable of putting out much, so I've been tossing around the idea of putting 6x9's (probably spr's as well) into the space behind the rear seat arm rest panels. Has anyone done this, would it work well or would I be better served to put a regular 6 1/2 SPR's on the rear deck.
I am also dissatisfied with the factory speakers, some of mine are at the end of their life anyway. I actually just bought Alpine SPR-17S for the front and Alpine SPR-17C for the rear (got a good price on them from onlinecarstereo.com, shipping was slow but it was also free so I can't complain). I wont be adding a subwoofer until much later.
It's impossible to get sub-woofer like bass without a sub-woofer. If it was possible to do cheaply and easily it would stand to reason that more people would be going that route.
With that said more surface area on the speaker generally allows for deeper tones so yes theoretically 6x9s would be able to produce deeper sounds than straight up 6.5" rounds. However, in my experience while the volume and tone range might improve, the overall quality and crispness of the sound drops significantly when going to an oval or square speaker. Personally, even if my car had slots for 6x9s I would use an adapter plate to fit round speakers in there... but that's just me.
I'm assuming by "arm rest area" you're referring to the large trunk pass through area. IMO this would be a bad location to mount normal speakers; however, it might be a good location to build a custom 10" Subwoofer enclosure without using up any of your trunk space (assuming thats the reason you don't want subs in your trunk). a high quality 10" sub will sound much much better than any hackneyed solution using 6x9s, and there are lots of options available for installing a sub without losing storage space.
EazyBreazy wrote:Also I dont know much about component sets, but how difficult are they to install. I have alot of experience with wiring and stuff like that so I am not afraid of that aspect, but very little experience with amps and Top Tier audio.
Crossovers are easy.
Basically a cross over simply decides which parts of the audio go to which speaker. Most amps have a cross over build in for subwoofers so that it only sends the low sounds to the sub woofer. Component speakers are no different.
Most speakers have 2 connectors, a positive and a negative. The Cross over units will have 6 connections, a positive and negative input that comes from your amplifier or head unit (this would normally go directly to the speaker in a non-component setup), then it has positive and negative outputs for both the tweeter and the mid-woofer. Simple really... 1 set of inputs and 2 sets of outputs... that's it. Some cross overs will let you adjust the cross over point, but most sets (like the Alpine SPR) are pre-tuned by the manufacturer for the best performance with their speakers) The hardest part is figuring out where to mount the damn things
EazyBreazy wrote:Another question is what amp, should i run to power just 2 - 6 1/2 alpine spr component sets and 2 alpine spr 6x9's. Im pretty sure i would need one to get the best sound out of them
Most power ratings are misleading... the most useful/accurate however is the RMS rating.
In my experience the best situation is to first check if the speakers have a MINIMUM power rating and if so ensure that your amp is at least above that. In general most speakers at the performance level we're dealing at don't have a minimum rating. Next you'll want to check the Maximum rating and ensure that you're below that...
Don't think that 110W RMS speakers need 110W RMS amplification to sound good, they'll still sound great at 90W or even 70W RMS. Obviously you don't want to starve them but over amplification can be even more damaging.
Find a decent quality 4 channel amp, you'll want to at very least ditch the factory amp since it's designed for the factory speakers, and those are altogether very different than the Alpine speakers you're looking to install.
Personally I'm just going to be running off of the amplification from my factory head unit for a few weeks while I research my amp options... this will also give me an idea of how well my speakers respond to fairly low lower and help me make better decisions about what I'll need for an amp and how much extra omph I'll need from a subwoofer.
