Circuit Sports Tie rods
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
Has anyone heard anything GOOD/BAD about them?? I need to get new tie rods asap and i was just going to get MOOG stuff or the Tein ones but the Tein ones are like the stock design and do not have pillow ball mount ends..I cant find any reviews or anything on these circuit sports tie rods anywhere I thought i recalled seeing a thread where someone installed them and someone else was talking about them being aluminum.. idk if thats true or not and it may have been the megan ones.. I would love to get the Kazama inners and outers if they werent $400 total hah
Anyways heres a picture of them for fun..
gumby74
While not using the Circuit Sports, I am using the Wicked Tuning product. After 4 months of use on a daily driven car, I have had no problems.I think Clawhammer is using the Circuit Sports tie rods/ends. If so, and assuming he sees this thread, I am sure he will chime in with a straight forward reply.
OM3GA
Im just afraid that (i dont know if these are made out of aluminum) but the MR ones have aluminum outters and having aluminum parts on such an important piece just bothers me... Alot of force + Aluminum threads = Death and totalled car.
gumby74
I agree wholeheartedly in regards to the aluminum.Unfortunately though, the turnbuckle (on the Wicked pieces) is aluminum. I still have my Tein set-up, and Lord willing, will not have to re-install them.
OM3GA
yeah im really afraid of the aluminum crap idk if the KAZAMA parts are aluminum too those are $200 for just the outers... I mean itd be close to $400 for kazama inners and outers!! AHH lol but if they arent aluminum that would be the more reason to get them but WHy the hell would they make those out of aluminum seriously.. is it that much cheaper for them?? i mean the weight loss is not significant enough to risk totalling your car and your life! lol
240SX805
Car: Black 1990 240sx HB
try megan tie rods i heard alot of good things about them i just ordered some yesterday..
r3v_v3ng3
Car: 91 fastback ka-t
i have one from ebay with the aluminum. nothing wrong with it, its holding pretty good except for the bearing (changed both of them with better bearing from aurora)
so i would be more worried about what kind of bearing they used (some use cheap sphearical bearing) that only last for like 2-3 months on regular driving.
apex760
Car: 1990 240sx
only after market i would trust beside kazama the teins i have or stockshttp://www.splparts.com/main4/main/default.htm
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
Nothing wrong with Aluminum tie rod ends, I've only ever seen viable proof on 2 occasions of them failing. Most aftermarket rod ends are aluminum anyway.
93bluecoupe
Car: 93 purplish blue coupe s13
one advantage is that the "ball joint" at the end is taller so it will correct your steering angles if your car is really lowered? the tein ones dont do that. just a thought
LayNLow240
Car: 92 240 coupe
Megan tie rods = fail.Grab ikeya formula inners and whatever outters they will allow. The inners are like 100 bux. Check znet for powered by max parts, they have them.
ddgsxr504
LayNLow240 wrote:Megan tie rods = fail.
ORLY?
I've had Megan Tie Rod Ends for over 2 years now with no problems. Just because you had a bad experience with them doesn't make them a bad product.
Nothing man made is perfect.
LayNLow240
Car: 92 240 coupe
Just because you have had good luck doesn't change my outlook on cheaping out on parts that keep your *** going straight down the road, and around corners. Megan is good for cheap **** like headers, manifolds, and exhausts. From the quality I have seen from their other parts, tack welded RUCAs, ****ed up tie rod ends/turnbuckles I will not trust my life to cheap **** for parts like that. But if you want to, then thats fine with me.
ddgsxr504
LayNLow240 wrote:Just because you have had good luck doesn't change my outlook on cheaping out on parts that keep your *** going straight down the road, and around corners. Megan is good for cheap **** like headers, manifolds, and exhausts. From the quality I have seen from their other parts, tack welded RUCAs, ****ed up tie rod ends/turnbuckles I will not trust my life to cheap **** for parts like that. But if you want to, then thats fine with me.
So are you saying that non cheap @ss parts don't fail? I can easily prove you wrong on that one.
NismoZRS
Car: 92 S13 Coupe
BUMP... for answers
No digression please..
OM3GA
Ive been running them for awhile with no problem. Im ultra anal so ill be buying Tein tie rods soon. A friend of mine has the newer designed CS tie rods with the cotter pins, and a few of his nuts came a little loose (come on be mature).
Good thing the pins exist but maybe check the nuts going through the knuckle every month or two for safety.
ZootedS13
Car: 1990 240sx se
OM3GA wrote:Im ultra anal
that made me lauph so hard lol
what ones did you end up getting?
