If you have to worry about how much your catch can holds, you need to invest in some new pistons.teddy wrote:I would imagine that just about any catch can, regardless of brand, are all going to do its basic function well enough. Although 30 bucks is a steal, I'd also like to know just exactly how much it holds.
Heh, this reminded me of an old 323 GTX I used to drive around (borrowed) that would fill up a 1ltr plastic vodka bottle (diy catch can) if driven under boost for more than a few seconds.Nismo_Freak wrote:If you have to worry about how much your catch can holds, you need to invest in some new pistons.
Lot's of patience my friend, lol. I took a pair of needle nose pliers, and shoved them in the hose, opened the pliers as far as I could, then shove it further in. I did this a few times, until it was streteched enough to go over the "T". You have to be quick though, because it will get smaller by the second, lol. Sooner or later, I am going to get the right size hose (and not clear), but that's gonna wait. BTW, I'd mount it as high as possible, that way it is harder for the can to be filled up. Also, you probably don't have enough hose if you mounted it where the charcaol canister was. I just mounted mine where the stock can was.Silverbullet91 wrote:Good god man, how did you get that hose on to the valve cover tee like that?
