circuit sports coilovers
knoxvillenismo
Car: '90 Nissan 240SX hatch. (sold)
'95 240SX S14 5speed. (sold)
back in the '90 hatch. ;)
So i installed the circuit sports street coilovers on my S14 last night and just wow. Fitment is perfect. As far as driving, they're very aggressive. I would compare to Megan tracks. They're pretty rough even on the softest setting. Only complaint is that the rears go STUPID LOW, and the fronts barely drop at all. Maybe 3 inches? I will post some pics here soon. They're very "drift oriented". They're literally so stiff, i cant get traction when pushing through turns. It's a very controlled slide, but still slows you down. Anyways, just my thoughts on them. I'll keep adding my thoughts as i drive on them more.
DrJuice164
Car: 04 G35 Coupe
Maybe try and put some helper springs on the rear? Not sure if circuit sport themselves sell em, but I am sure you could find either stance or swift or whatever have you brand that would fit (depending on your spring diameter)
rioredstang
Car: 1993 240sx SCCA ITS
These have threaded bodies. Did you loosen the lower nut and adjust the body to get ride height? Did you have alignment after install?
knoxvillenismo
i got them a little softer. the knobs were a little still since they were new i guess. Still a little rough tho. But yes these have threaded bodies. i had to raise the $s!t out of the backs. But the fronts are pretty much maxed out. Bodies all the way down and collars down. That's a little disappointing. I'm getting an alignment after i get some RUCAs. there is sooo much rear negative camber that its stupid. had to raise yet again to lose some camber.
