Cigarette lighter not working, Fuse Ok !
Dino713
Car: 2012 Infiniti M37 Premium Pack
Hello .... My cigarette lighter is not working ... Fuse is ok, lighter is new .... Plugged the charger just to see if there is power supply but there is none. Any idea on this or do I have to change the whole cigarette Assy ? Help would be really appreciated.
Thanks
ezb57e
Test the center contact with a test light.
Is there power there and ground on the rim?
I think there may be more that one fuse for the power outlets.
securityguy
Car: 2012 Infiniti M37x
There is only one fuse per electrical circuit. It will either work or it will not. Agree on checking the contact inside the lighter so see if power is there.
Dino713
No power ! Checked with the tester this time. Could it be wiring ? FYI, this is a pre-owned vehicle, non smoking and seems like the lighter was never used.
Panzer Leader
Car: 2012 M37S; Formerly owned a 1994 Infiniti J30t and 93.5 G-20.
If you can pull the lighter, my guess is a disconnected wire on the plug. Might just need to be re soldered.
Dino713
Went to dealership and they changed the fuse and it worked, cost $0. I had put the spare fuse (Infiniti recommended) which was btw also brand new did not work. Tech told me if the lighter is not used with the car charger, it is definitely the fuse :)
ezb57e
ezb57e wrote:Test the center contact with a test light.
I think there may be more than one fuse for the power outlets.
How did you check the fuses?
Visual checks on fuses are never good enough.
You have to use a test light, or stuff like this happens.
