since looking at the infinity tech documents i was pointed to, i learned that the cigaret lighter and 12 volt power in glove box are connected to the same relay ACC relay, they have seperate fuses though.
The "hot" wire is on one side of the relay then all the accessories are on one side... its an interesting setup... it looks like they tried real hard to make sure the accessories are not "on" unless the key is in the "acc" or "on/start" position... the diagram shows the cig lighter and 12volt power sharing a common wire with all accessories on the car. But they dont share a fuse... so i know each one is isolated, as my cig lighter fuse was blown when i got the car, but my 12volt still worked.
since the accessories share a common wire i dont think it would be easy as "jumping" the hot wire around the ACC relay to the 12volt and cig lighter with out maybe engergizing the other accessories in the process. But that was a top level diagram.. so it may be different once i pull the wires out.
the diagram can be found here (wire diagram\accessory power ACC)
http://www.nicoclub.com/FSM/G3...g.pdf
Has any one done this yet?
