BamaCoupe »
https://forums.nicoclub.com/bamacoupe-u122644.html
Thu Mar 19, 2009 4:28 am
You sure they're chrome, because chrome wheels are generally easy to keep clean and keep its shine with little to no work. Now polished aluminum is a different beast and sound a little more like what you may have, and yes polished aluminum looks like and shines like chrome to someone that does not know the difference. Even though Polished Aluminum is more high maintenance I still prefer it over chrome, because it's more affordable and much much much (I can't same much enough) lighter then chrome. If I am correct and you do have polished aluminum rims rather than chrome use a wheel acid to clean; this will dull the piss out of them, but cleans the surface thoroughly, then use a wheel polish (I've heard most prefer mothers wheel polish) and polish then out and they should shine like the day you got them. One thing though is you should not have to do this to the rims but once every year or two. When cleaning your car do you shimmy (spl) your wheels first and thoroughly? Because with polished aluminum this is very important or you will have water spotting that may never come off. If I'm wrong and you do have chrome do not do what I mentioned for polished aluminum; chrome is very low maintenance with only washing and drying required. I've owned both chrome and polished aluminum wheels for long periods of time and never did I have to polish the chrome wheels, but the aluminum was a different story.
